iEverything
- Jan 2, 2009
Hi,
Hopefully someone out there had the same requirements as me and managed to find a solution....
I have a Apple eco household with a Mac Pro, iPad 2, 2 iPod touches and 2 Iphone 4's which all need to have video streamed to them @ some point.
My current setup is a PS3 connected via HDMI to a Samsung LCD where .avi's and other formats are played to the TV and the major mission of having to try get media copied locally to all the other devices when is needed.
After extensive research it looks like my best option is a HTPC type device, we have 2 laptops (Mac Pro / Win 7) @ home which are not always on, so dont want to use them as a media server, I also really dont have the space to have a server / desktop running in a corner. So I am looking for a compact device which also has bluray (to replace the PS3 since we only use it for blu rays and a media server locally to the TV) which can just slot into my existing LCD type unit
the other prob is trying to find kit like this locally which is difficult....
Best bet so far is the Asus EeeBox EB1012P Desktop Computer but it has no blu ray, if the ASRock CORE 100HT-BD was avialble locally and a reasonable price it seems like the ideal solution.
So in summary looking for a OS based media server which will stream via WiFi n to the IOS device and connect to my LCD via HDMI, have a HDD and a Blu ray player
Any other suggestions?
Russ
Russ
