Advice on LED strips
Tech_
Jhb
Hey All
I’m looking at putting some LED strips on the back of my TV or behind my floating TV unit to give it a bit of a fancy look. Any suggestions/advice as I’m new to LED strips and it seems there is so many options available.
I can vouch for Govee. I got their Christmas tree lights this year.
They have a good range of various lighting products. Great quality and a comprehensive app. I would look at this kit
Their products are also available from Takelot.
I’ve seen Govee products and the backlight 3 lite has already been added to my cart however my bank balance says I should wait…
This is what I was thinking of getting as a start.
I would suggest getting the more modern Backlight 3 that uses a camera rather than this, since this seems to just be static LEDs
Looks interesting....but R2000?
Yea, this stuff is expensive. The Phillips Hue even more so, the sync box is like R5000 alone and then it doesn't even support HDMI 2.1, pass!
Think I'll just get some basic strips and set it to a static colour for some ambience...
I do like it though....a lot...maybe if it was a little cheaper....
I've also looked at these but can't get over that weird camera sitting on top of your TV. It would distract me 24/7.
I would hazard a guess that the camera would "disappear" after a few days with the extra immersiveness from the colours around the TV.
I put a lamp without a shade behind my tv. Works great
If you want cheap these work very well.
The L2 is pretty much identical but comes with its own power supply. USB of the L3 makes more sense as the TV can likely run it for you but that all depends on what you want.
This looks better the Govee TV Led Strip that I was looking at as
Strip is 3m more and R100 cheaper with delivery which is def bang for my buck
oh and theres the option for connecting to USB port on TV or adaptor if I wanna use it elsewhere, so thanks @SauRoNZA
Curious to know if you can buy another controller seperately and connect the leftover led strip to it or do I have to buy a whole new kit and end up with various length offcuts of LED strips
I’ve seen them separately I do recall.
And I know you can buy even more strips.
There’s also an individually programmable version if you want to get really fancy.
Let me do some digging on the seperate controllers.
I'm just at the beginning of the LED journey so lets see how it goes before I start using the fancy stuff
Seems it's the L2 that has the separate controller.
But I see now reason why you couldn't use an L2 controller with the same strip, that one just plugs in.
Worth asking them.
Has anyone bought and fitted the Sonoff L3 strips. Was it easy to install and what is the experience like?
