Advice on pc components
newdeal
South Africa.
Hi Guys
I would like to build myself a pc and have chosen the folloing components please give me your opinions and also...... is what iv'e chosen compatible with each other.
Keeping in mind that I only have about R2000.00 to spend
I chose everything off digitalplanet.
Case: www.digitalplanet.co.za/shop/product.asp?stockID=89831
IT-CM-07_BLACK_XX350_12CM
PRESTIGIO Black ATX Midi Tower Chassis (24-Pin, 2 * SATA, 350W PSU, TAC 1.0, 120mm Fan)
Motherboard: www.digitalplanet.co.za/shop/product.asp?StockID=94843
P4M800P7MB-RS2H
FOXCONN INTEL/SKT775/DDR2/VGA/LAN/AGP/SATA Motherboard
Processor: www.digitalplanet.co.za/shop/product.asp?stockID=72628
BX80547RE3066CN
Intel CPU Celeron-D 346 Processor - 3.06GHZ, 256K L2 Cache, 533Mhz Frontside Bus, Intel EM64T, Execute Disable Bit
DVD-writer/CD-writer: www.digitalplanet.co.za/shop/product.asp?stockID=77511
LGGSA-H20L
LG 16x DVD Writer (Retail Ivory) Lightscribe
HardDrive: www.digitalplanet.co.za/shop/product.asp?StockID=80090
Hitachi Deskstar (80GB) 7200rpm 2mb cache Desktop Hard Disk Drive
Card Reader:
Vantec ugt-cr900, internal IDE card reader with 1 USB downstream port for 3.5 bay- CFI, CFII, SD, SM, MMC, SD, MS, MS Pro, Ms Duo, Ms Pro Duo - with black and beige interchangable face plate for 3.5
Please can you let me know if everything I have chosen is compatible and will work well together.
Is there anything else like cables etc. that I would still need to purchase to complete this.
Any opinions on my choices or advice would be greatly appreciated.
I already have one SAMSUNG 1GB DDR2 PC2-4200 Memory 533mhz is this ok with what I have put above.
