Advice Required - Wireless Gaming Headsets & 4K Monitors
Zarathustra
South Africa.
I am hoping that someone has some first hand experience and is able to recommend the following:
- 4K Monitor
Based on best value for money & quality.
Any advice is welcome :)
I can't help on recommendations, but if it's for gaming I wouldn't go 4k (rather look at 144hz monitors).
Are you 100% sure you want a 4k monitor? Do you have the new Titan XP?
Get a 1440p monitor.
4K not worth it imo., especially with the lack of GFX cards that can give you proper performance at the resolution.
If you not into FPS then 144hz might be unnecessary? Can someone clarify this?
Wireless headset + gaming?
I think your trying to flash your setup instead of optimizing it for gaming...
I recently got the rog swift pg348q. I have the pc to run it though...and so far no complaints or regrets my side. I am enjoying my games and videos etc.
Yeah, not all game types benefit as much from the hz increase.
Games with more static scenes and/or where only little parts move (for example a moba where a handful of characters/backgrounds and effects are moving) will benefit less than an fps where you're looking around constantly.
