Hi,
I have a web server (Windows Server 2008, Web edition) at home, connected to my ADSL line via a DGN2200 router. I use this server to host a few specialized web applications and I also use it as a FTP server. Accessing the server is by a domain name, by using DynDNS services. A few databases (FireBird) replicate to this server by using port 3050.
Last year Afrihost convinced me to transfer the management of my ADSL line from Telkom to them.
Before the transfer, when Telkom managed the ADSL line, every thing was OK regarding FTP access and database replication but after the transfer (with the 105 floating IP addresses assigned by Afrihost to ADSL lines under their management), I experienced the following behavioral problems with the server.
From inside the LAN where I’m employed, thru a Squid proxy server, I cannot FTP to my server at home although my friends using this FTP server can access it from their residential homes. One friend uses the wireless services of Vodacom and one uses the wireless services of Cell C. From inside the mentioned LAN of my employer, I can FTP to public sites such as ftp.RhinoSoft.com
If I try to ftp from the LAN of my employer, the Netgear router logs show:
Firewall: packet accept. 196.33.85.3(54793) --> 105.236.11.210(21), Protocol TCP.
Wednesday, Nov 21,2012 12:48:48
Now my request: I want to test whether I can FTP to a server on an ADSL line, managed by Telkom (using floating IP addresses assigned to South Africa). If you accidently have such a configuration, will you configure me a temporary account (read only) and contact me at nols dot smit at gmail dot com ?
Your help will be highly appreciated,
Regards,
Nols Smit
Regards,
Nols Smit
