Afrihost Pure LTE topup data questions
Jake45
Does anybody know the order in which the Afrihost Pure LTE topup data gets used?
If I purchase a 25GB topup data bundle and all of my peak data has been used up but I still have night data available, will the topup data be used instead of the remaining night data during the night data hours?
If I still have topup data available at the start of the new month, will this get used up before the new peak data or the night data is used?
If anybody else is interested, it appears that the topup data does not get used after midnight if midnight data is still available which should allow you to assign all of the topup data to only peak times which makes the topup data much more useful!
I haven't been able to check yet what happens when new peak data is loaded.
It is possible that any remaining topup data will not be accessible until all of the new peak or all of the new midnight data has been consumed which would effectively result in any remaining topup data being wasted as you would normally not want to use all of your peak data before the topup data expires after 30 days. I will see what happens at the start of February!
I hope that the night time data window is going to remain from midnight until 6AM and not end an hour early at 5AM as mentioned in some of the other MTN contract data threads!
