Aftermarket Navigation Unit Fitment
aquadat0r
Gauteng
Hi all,
I'm looking at upgrading my factory radio in my 2013 Hyundai Sante Fe with one of these http://goo.gl/2di7go.
Does anyone have experience with these units being shipped? Who do you suggest for fitment in the Randburg area? Are there equivalent units available elsewhere?
Johan
Hi all,
Johan
Looks identical to the A/M one that we fit.
I don't like it, as it is nothing like as easy to use as a Garmin - in our case it also messes up our Bluetooth and USB connections, which might not be the case in a Hyundai. Ours also costs 4 times as much, so I'm a little worried about the quality you would have.
Can't you install a version of Garmin on Windows CE?
Besides, if it has 3G, so isn't Google Maps an option?
