Am i registered for tax?
lilggg
Durban
Hi, i recently started working and was told i need to register for tax, but my payslip shows i have a tax number? Does this mean i'm registered?
Have you asked SARS?
But yes, it would suggest you're registered.
X% seems about right though I'd suggest editing your post since you can deduce your salary from it.
And no, if anything its low. Remember 18% is the lowest tax bracket, 40% is the highest.
According to the Sars website you need to register within 60 days of starting to earn a taxable income.
(http://www.sars.gov.za/TaxTypes/PIT/Pages/default.aspx)
I am not to sure if you might have been registered because you started working (maybe the company registered you). I can't remember the process. Did it many years ago.
http://www.oldmutual.co.za/markets/south-african-budget/income-tax-calculator.aspx
Use the above link to see if you are being taxed to much. Depending on your salary 10% isn't that much. (seeing as the max is about 40%)
Also have a look at the following ta tables to see more or less in which tax % bracket you are supposed to fall.
http://www.sars.gov.za/AllDocs/OpsD...Trusts for 2013 and 2014 - External Table.pdf
Cool thanks a lot. According to the calculator it's correct.
If you have a tax number, you are registered. I suggest you register online as it will make filing tax returns easier
