gerasmus
Good afternoon forum,
Device: Viewsonic Viewpad 7 with 3G & SD card expansions.
OS: Android 2.2
RAM: 512Mb + 8Gb mini SD memory.
Additional: GPS, Gravity sensor, compass, thermomeoter etc.
Bought it where/when: Nederland (den Haag, NL), 08/2011.
Issues: "Out of memory" notifications.
Could the memory notifications be due limitation of the Android 2.2 OS ?
I even get "not enough memory" messages when launching apps, this can even happen directly after a restart (and restarting the device doesn't seem to make a difference). Any App (like standard Browser and Maps) tend to end unexpectedly, and the only way to recover is to reboot the tablet.
I thought that 512Mb Ram would be plenty of memory for a tablet ? I've moved all the apps that could run from SD card to the external memory, installed an auto memory manager/purging app, cleared memory wasting apps from startup. Once I get home I can post a screenshot of the resources available.
Here is what typically happens:
Star the device, launch an app and then it can either luanch or (in many cases) display "Out of memory" or "Out of space". This can happen either when trying to launch or install apps from Apps Market or when trying to launch an app. I then use memory mangment app to purge memory, then restart the device, try again and as you can guess I still have the same issues.
I am considering a Android 2.3 or Android 3 device with 1Gb Ram, but 512mb seem to be the most common. I even found a Chinese dealer that can custom load the device with Android 2.3 or Android 3, if so desired. Only thing is that the device will have only 512Mb Ram.
Luckily I I bought the device for a LOT less than what it would've costed in SA. Due to not being happy with this device I am considering to buy another tablet, but before I do, I would like to make sure that I don't run into the same problems again when buying another device. I've found quite a few web shops where I can import from China directly for a LOT cheaper than buying from a local SA dealer.
Questions:
The Chinese dealer confirmed with me that they can load it with Android 3.0 if so desired. Click here to see what I have in mind.
Thank you,
Willem
OS: Android 2.2
Questions:
- Could the memory notifications be due limitation of the Android 2.2 OS, other words, does Android 2.3 and 3.0/3.1 have better memory mangement?
- Would it make a difference if my device had 1Gb Ram ?
- Does the amount of buil-in RAM make a difference how many/which apps the device can run ?
Thank you,
Willem
