Kloofvreter
Good people, I am literally at my wit's end with this issue.
I have an LG G3, working perfectly fine. Then all of a sudden yesterday it would not connect to my wifi at home. Restarted the router, the phone reconnects for a minute or two, then goes back to mobile data. I have changed authentication, changed the channel/frequency, SSID , password, everything. Nothing works. This was working fine for 2 months. The strange thing is, at work it works perfectly, and at home, the SO's phone (Android), and laptop works perfectly.
No matter how many times I forget the network and reconnect to it. It simply says connecting, then saved (sometimes authentication problem), as indicated below. It's little niggles like this that made me dislike Android from the start, although I was not yet motivated enough to switch to iOS.
