Android help
marine1
A black hole in the universe - JHB
Hi guys am using Samsung note tab 10.1
What I want to know is if have a lot of pdf files I want to view like a magazine, so having the swipe page function. What do you recommend?
The other issue is I cannot log into mybb on tapatalk on the tab. I enter username and details but it just goes to guest.
Any idea?
Using 2.4.13
Any idea?
Using 2.4.13
Hey marine. Check out Montano reader. Free version should do what you want.
No idea on the tapatalk issue.
Try out Radaee PDF Reader. It's the fastest out of all of the ones I've tried. Highly recommended from me.
Any idea?
Using 2.4.13
You can try clearing the app's cache / data. You can do this by going settings => apps => click on tapatalk => clear cache
Adobe Reader does that out the box, you can set it to single page (swipe to turn the page), to continuous flow etc etc, and its mahala
