Android tv box and android tv
RobRamos
I have to say the Xceed tv box has been a complete waste of time. Not certified product although it's loaded with Google play store and services. Netflix doesn't run anymore, dstv now doesn't run anymore and this box was R1000.00
Skyworth tv 40". So now this device is not certified to run Netflix?!?! System freezes when you change the volume. System freezes at random times.
I am thinking that Android tv related devices are a complete waste of time and money. Looking to Apple tv now even though I am not a high apple fan.
I have both the Xiaomi Mi Box and Mi Box S in my house and could not be happier. Never had any issues with them and they're both Android boxes
Of the two, which is better, which do you prefer?
There honestly isn't a massive difference. The S is obviously that little bit faster and the remote is better (simply based on the button layout) imo
You have bout a media box, not an android TV, they are 2 completely different thing. What you have is a TV box running android mobile os with a TV theme.
They worthless, nvidia shield, xiaomi mi box and mi box s are the only 3 android TV devices available in da, everything else are android media boxes. Pretty much useless for anything not on your network or hard drive.
Performance is **** because well, your using a spanner to knock in a nail, with your non dominant hand, blindfolded while your wife is tickling you and your dog is jumping on you.
Unfortunately your are the bictim of bullshit advertising, but you cannot go and say android TV is **** when you have quite literally not used one.
The lit box and emmatic are also legit options
Forgot about lot, not heard of the other one. But ya, skyworth, my gica and most of what they drop on one day only should be avoided unless you can confirm its runned genuine android TV os.
I was trying to find the words but you stole them right out of my mouth
