Any ISP offering speed limited 2Mb uncapped Trials?
Totempole
Other than MWEB (I used their Uncapped Trial a while back), are there any ISPs that offer 2Mb speed limited data trials?
It doesn't have to be Uncapped, just needs to be speed limited to 2Mb. I'm thinking of possibly downgrading my line speed, but need to test whether 2Mb will be sufficient for my needs.
Depends what you are trying to speed limit? You could do it yourself or on your router.
You can do that just by calling Telkom. They can set your line to 2meg on the phone. Then you can call back the next day and put it back up to 4meg.
Thanksfor the info. I don't want to involve Telkom where I don't have to. They've screwed things up too many times. I'd rather just try to limit my own connection using the tools suggested by biena. I don't think my router has the capability to reduce sync speed to a predefined setting. It's an old Telkom DG834GUv5 supplied by Telkom in 2009.
