Any REAL software to speed up system and clean it?
Mr.CookieMonster
East London
Hi,
I got a message pop up on Windows 7 Saying my PC is performing very slow. Im worried because my specs should accomodate for heavy computer usage.
I would like to know if there is any REAL software that I can use to speed up my system as well as fix issues that are causing it to be slow.
Thanks.
registry mechanic. but sounds like you got malware
+1.
OP... Was it on your pc itself or on a website?
On a website means nothing (other than "download this pos") but on your pc means poo poo. Aka malware.
Since when does Windows tell you its performing slow. The only places I've seen those are pop-up ads.
Run CCleaner. Gets rid of all, strangely enough based on the first C in the name, the cr@p.
I also regularly run Spybot Search and Destroy and Adaware. I then use Defraggler as I somehow think it is better than the built in one (but this has no proof to substantiate it).
You can always go and get IObit's Advanced SystemCare software, which you can download for free here: http://download.cnet.com/Advanced-S...07614.html?part=dl-6271865&subj=dl&tag=button
CCleaner is great if your problem is related to too many temporary files on your system.
ClintX:
You're most definitely right about Defraggler being better (and faster) than the built-in Windows one.
I started using Smart Defrag 2 (also from IObit) quite recently and it is working much better than the Windows one, but I can't say how it compares to Defraggler, because I haven't used that in a while.
IObit makes pretty awesome freeware utilities: http://www.iobit.com/recommend/freeware.php
Have you got a good antivirus/malware app installed? Where does the message come from? Have you tried Googling the exact term used? Remember to put the message in quotation marks ie. "Your system is running slow"
This is a screenshot of what I got:
The best software is the Invoicing system at the computer shop that will print you out an invoice when you buy a faster processor and more RAM.
You can try SysBoost 12
Its the best cleaner I have used to date.
  • Cleans Windows registry
  • Gets rid of viruses, Also prevents future infections
  • Removes all known malware
It really does speed up your PC big time. Best of all its totally free.
This solution will take me days to download, literally. :D
I need fast, quick and instant solution.
Hey I tried, oh well you can go try ccleaner
But also using http://technet.microsoft.com/en-us/sysinternals if you a pro can help you solve almost any kind of problem on Windows, you just need to know where to start.
I really think they should have been part of the OS esp now that Microsoft "Bought" em.
Sysinternals quick run down
Start with:
