C Compl33t Senior Member Joined Feb 1, 2005 Messages 993 Reaction score 0 Feb 19, 2005 #1 of a WiFi card to increase the output? I've got a Gigabyte WPKG...
D Decotey Expert Member Joined Oct 14, 2004 Messages 1,063 Reaction score 2 Location . Feb 20, 2005 #2 U should speak to TheRodent
D daffy Expert Member Joined Jun 24, 2004 Messages 1,134 Reaction score 19 Location . Feb 20, 2005 #3 Jawug has been hacking away at the firmware for some gigabyte AP's, without much success. Gigabyte actually released the Source for their Firmware under the GPL, but no-one has been able to get a successfully built firmware from it.
C Compl33t Senior Member Joined Feb 1, 2005 Messages 993 Reaction score 0 Feb 21, 2005 #4 Thanks for the reply. Would the JAWUG kit be sufficient to start a WUG in other areas, or is it optimised for use in your WUG?! http://swug.atspace.org
D daffy Expert Member Joined Jun 24, 2004 Messages 1,134 Reaction score 19 Location . Feb 21, 2005 #5 The JAWUG Kit will work anywhere. Just specify that its for a Different WUG, and we wont load the Jawug firmware on it
C Compl33t Senior Member Joined Feb 1, 2005 Messages 993 Reaction score 0 Feb 21, 2005 #6 ah...but you see...i'd like the access point to have a higher output than normal...what language is the OpenSource firmware written in? Assembly?
D daffy Expert Member Joined Jun 24, 2004 Messages 1,134 Reaction score 19 Location . Feb 22, 2005 #7 We'll put the normal OpenWRT Firmware on it, which will allow you to do all that nifty stuff. But for Jawug we're writing some extra goodies for OpenWRT which will make it a little more automated. (www.openwrt.org)
C Compl33t Senior Member Joined Feb 1, 2005 Messages 993 Reaction score 0 Feb 22, 2005 #8 Thanks....I'm busy saving, we're planning to be up and running with the first two nodes by March/April. I'll get in touch with you
