Anybody with a Scout 2 able to help?
Comango
Well hi!
I'm currently looking into getting a Cooler Master Scout 2, because I think it will just look awesome with a NZXT HUE I'm also thinking about getting, but I just need someone with a Scout 2 to tell me whether you think a led strip would be able to fit between the front panel and the actual case without the actual strip being visible from the outside? Also, how easily does light get through the front panel and do you think a HUE would look cool on the case?
Thanks in advance.
I have a scout 1 and light easily gets through the front, I'm sure if you google scout 2 and nzxt Hue you should get something.
