Anyone using Lantic ISDN?
BitRogue
Roodepoort
I see the prices at Lantic ISP (www.lantic.co.za) for ISDN dual channel is pretty reasonable - R90 a month vs TelkomInternet's R109 a month for single channel.
Is anyone with @Lantic and how is their services and line quality/bandwidth?
I would consider changing ISPs at this price.
So no different to what I get now. Just cheaper. I think I'll change at the end of August. thanx
They are not great, but the service level's are adequate. Check your monthly bill. Make sure you don't get charged for something you don't want.
Otherwise, not too bad.
Im with them ATM with my 64k, been there for almost 2 years now... As things look now, ill be leaving them when I get my ADSL for the obvious(pricing, caps, the usual) reason and another small reason thats a bit too close to home for me *cof* :)
Their call center isnt the best around, but most of them try to help you as far as they can. I cant recall having any problems with them in the past, except for when i forgot to pay and took it out on the poor oke on the other side.
Just make sure about the packages: a Month or so ago, I phoned them asking about the new prices, and the oke told me that that is base, just for the connection, nothin more, nothing less.... Just make sure aobut what you get for that price ect ect.
TelkomInternet = Lantic (as pointed out by mc) so the only difference is support and price
