Anyone using Meteor?
eternaloptimist
Just wondering if anyone is using Meteor? What are your thoughts on it? I'm to learning node now and wondering if it should be my next step?
Cheers
Meteor is very good but it does lock you into their way of doing things (not a bad thing as the stack is top notch).
Before you make your choice, perhaps check out mean.io and meanjs for stacks that depend on Node and give you a lot more flexibility without sacrificing any power or the "wow". There are also many other javascript or node stacks which may suite you better too.
