Anyone using Zoom Player
swordfish1
hi,
I wonder if anyone here is using zoom player, in particular version 3.0.
I just installed second sound card and a pair of cheap desktop speakers, and I want to make winamp and zoom player play via my main sound card while everything else via the new one, which I made the default one. The winamp is easy, you just change the sound output device and there you go, but how do I change the sound output device on the zoom player?
any ideas?
If you are using a newer version of zoom player, can you change the output device in it?
thanks
ok I sorted out the problem myself ... it is seriously advanced stuff
in case anyone wants to know, you go to Player Options -> Manual Filters, enable Custom Media Audio, click on Filter manager, make sure all filters have "Current merit" set to 00200000, except the one applicable to the desired output audio device, whose Merit must be set to 00800000.
easy stuff ... :D
