Dolby
- Jan 31, 2005
Hi,
A few weeks ago I bought a Pinnacle Systems Showcenter 200 meda streamer (www.pinnaclesys.com) and purchasing a Pinnacle Systems PCTV 110i card in the next week or so. The Showcenter is connected directly (Adhoc) to a Linksys 802.11b/g PCI card. They're about 4 metres away with a single wall in between.
My problem is that the PC says 'only' 80-90% signal at such a near distance! Also, when I bought up, the PC first tells me 11mbps, then 12, 18, 24, 36, 48 and eventually 54mbps. The process takes 5 minutes before the signal is at the fullest (at which it connects nicely). Is this normal? Is there a larger antenna one can buy to increase signal?
My two other options are a) get an AP and b) wire it with ethernet. Using an AP will the signal be stronger?
