die koning
- Apr 2, 2013
Hi,
I did programming a lifetime ago, and don't have the time for a small application needed for one of my clients possibly.
It just needs to display the information in realtime currently displayed on a Iconix FX21 unit's LCD display, on another preferably normal PC LED\LCD display, otherwise let me know what the options is.
I have the control codes, more information can be required from the manufacturer to communicate with the device.
They recommend using the serial port that's available, currently using that to communicate with the PC for the standard software to show reports, but it lacks functionality to display real-time information. Basically just the weight of the animal that will get onto the scale.
Another option will be for someone to open the device and connect another LCD display directly to the unit that can be extended a few meters and no programming required then I reckon.
Please advise or let me know if you need more information or if someone can point me into the right direction, it will be appreciated.
Thank you.
Thank you.
