Hey guys, I am planning to have a LAN party and I'd really appreciate some advice.
1) Are stranded cable RJ45s necessary or can I use solid cable RJ45s? Is there a big difference?
2) I suppose stranded cable is a must? I've heard that stranded cable has a lot more attenuation per meter and that stranded cables should be kept to a minimum distance. What exactly is still acceptable? The run from a switch to a PC would be a max of 2m (maybe a little more but not much) so that should be fine?
3) Should I use solid cable for the gigabit (100Mbps would be fine but gig speeds would be preferred for file transfers) link between the switches or would stranded still be fine? This would be a maximum of 10m.
Any help would be appreciated.
