Asrock P4VM8 PCI problem...
PHTech
Witbank
Hi...
One of my clients' PC's uses an Asrock P4VM8 Motherboard. . . I have tried to install a Mecer PCI Bus to PC Card Adapter, but after installation of the PCI card, the PC wont seem to boot into Windows XP. If I remove the card it is working fine. . .
I have installed the card in separate machines to see if it isn't the card, but it isn't. I have also installed other PCI cards into the Asrock Machine, and its working, but NOT with the PCMCIA adapter. . .
Any help / suggestions...
