AstraOwner
- Jan 14, 2018
need help to what may be causing my fans to run constantly as soon as ignition is turned On..this started after i changed a cracked radiator .thermostate was stuck open all the time so i had it replaced aswel.my coolant light stayed on since the radiator change..had car diagnised and a code error P1540-8 came out which is A/C SYSTEM HIGH PRESSURE...both fans are running even when aircon is not switched on...so what cn this be...had few different opinions from these mechanics which is not pointing to one problem..one said its my fan motor thats broken,one said its the bleeding but it was bled correctly,one is saying its my cooling module....please help
