Asus Memo Pad 10" LTE and Viber installation
theunsheydenrych
HI
I want to buy the Asus Memo Pad 10" with LTE and install viber on it.
The question is, will it work, as far as i understand with the installation of viber you need to be able to receive a sms on the device you install viber with.
I plan to get a vodacom data simcard for the divice, so i should be able to receive sms's, right?
The main concern is the ability to receive sms's on the device, will this be possible or does the tablet need al sorts of other hardware?
Regards
Theuns Heydenrych
