Asus Zenfone Max Pro (M2) ZB631KL display screen is a capacitive 6.26 inches’ touchscreen display. The Asus Zenfone Max Pro (M2) ZB631KL Price is $300. This device runs on an operating system of Android 8.1 (Oreo). The Zenfone Max Pro (M2) ZB631KL’s rear camera is a dual 12 MP and 5 MP rear camera. The front camera of the device is a 13 MP selfie camera. It comes with 3 GB/4 GB or 6 GB RAM. A non-removable Li-Po 5000 mAh battery with fast charging powers the Zenfone Max Pro (M2) ZB631KL.
The screen of the Asus Zenfone Max Pro (M2) ZB631KL is an IPS LCD screen of 6.26 inches. The screen has a resolution of 1080 pixels by 2280 pixels. The screen-To-Body ratio is about 82.0% while the pixel density is 403 ppi. The device comes with Dual SIM (Nano-SIM; dual stand-by).
The operating system of Asus Zenfone Max Pro (M2) ZB631KL is the Android 8.1 (Oreo). The Zenfone Max Pro (M2) ZB631KL Chipset is a Qualcomm SDM660 Snapdragon 660 with 14 nm manufacturing process. The CPU is a Octa-core (4×2.2 GHz Kryo 260 & 4×1.8 GHz Kryo 260). The graphic processor is a Adreno 512.
The Zenfone Max Pro (M2) ZB631KL has a body dimension of 157.9 mm long by 75.5 mm wide by 8.5 mm thick. The device weighs 175 g. The device color versions include the Blue and Titanium versions.
The Zenfone Max Pro (M2) ZB631KL has one version of internal memory which is 32 GB or 64 GB internal memory. And this internal storage be supported with a microSD card of up to 512 GB on a dedicated slot. The 32 GB or 64 GB internal memory version comes with 3 GB/4 GB or 6 GB RAM.
The rear camera on Zenfone Max Pro (M2) ZB631KL is a dual 12 MP and 5 MP rear camera. The camera comes with LED flash, HDR and panorama. You can capture videos of about 2160p resolution with the rear camera of the Zenfone Max Pro (M2) ZB631KL. The front camera on the device is a 13 MP camera.
The device has GSM, HSPA and LTE cellular networks. For 2G band you have GSM 850 / 900 / 1800 / 1900, on 3G band you’ll get HSDPA 900 / 1900 / 2100. For 4G band you get LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 8(900), 18(800), 19(800), 26(850), 28(700), 38(2600), 41(2500). The internet speed of the Zenfone Max Pro (M2) ZB631KL is HSPA 42.2/5.75.5 Mbps, LTE Cat4 150/50 Mbps.
The Zenfone Max Pro (M2) ZB631KL has a rear-mounted fingerprint sensor. There is an Accelerometer, proximity, earphone jack and a loud speaker. The battery is a Li-Po 5000 mAh battery with fast charging.
Source
Source
