Sigh.... guess what... this problem is back again..
I have the following system, about 2 years old:
E6600,
ATI X1950XTX 512Mb ram card
3 gig ram (mushkin 2 x 1 gig and corsair 2 x 512 mb)
2 x Hard drives
500W PSU
Gigabyte Mobo (DQ 6 or something like that)
LG DVD writer
SB Audigy 2
My problem is that I have been in jhb for 2 months now (from CT), and the last month, my comp has just started shutting down while i was busy on it, and then not starting up properly again.
It also sometimes does not want to start first thing in the morning after being off the whole night. All the fans (cpu/gfx/extra fans) are running though when i press the power button. The DVD drive opens and I can hear the HD's working. The screen however stays blank..
The gfx card has 2 LED's that come on when this happens. The one LED says T_fault, the other Ext Pwr.
I did some looking on the net, and it seems that most guys who have had this problem have either put it down to the gfx card or PSU going. Murphy also is having fun here, cause when i take it in to 1 computer shop, it starts fine with no probs, but when i take it to anther shop, it does not start, like i explained above.
I wanna know if anyone else out there has had the same problem with ATI cards and what they did to fix it, cause i dont wanna go spend R1000+ to replace a PSU / gfx if that is not the problem..
E6600,
2 x Hard drives
500W PSU
LG DVD writer
SB Audigy 2
