I'm hoping some of you have some insight into this:
I'm looking to get a Atom based system that'll serve as a PFSense/IPCop firewall for a small business. I've been toying with the idea for a while now but I could only find complete solutions (IE. Asus EEE Box), they only have a single Gigabit LAN, they have active cooling, they are fairly expensive (although I'm willing to pay for the cheapest version) and finally I can't tell if adding another Gigabit LAN is even possible.
My brother told me a guy at work bought himself a Atom based motherboard with the CPU attached and then just made his own build. That is what I'm looking for. Bare bones that allows me to add to it.
Either just a motherboard with CPU (maybe a case and PSU would be cool also) or worst case scenario a complete solution that allows me to add extra PCI devices.
The only requirements are:
Low cost
Low power
At least one IDE or SATA port
At least one USB port
Plus points would be:
Atom CPU
Integrated Wireless (b/g/n)
Integrated Gigabit LAN (x2 preferable)
Motherboard/CPU/PSU only (passive cooling preferred)
Thanks for any help!
Low cost
Low power
Atom CPU
