CntrlAltDel
- Jul 21, 2010
Hi there,
I'm intending to wire up a automatic transfer switch to switch between main and backup power just for the 2 lighting circuits. Both of them seem to be connected to a "hot" neutral link bar (not protected by earth leakage). I assume it was done this way because none of the lights have any fans that require isolators.
My question is, since the neutrals for the lighting circuits are connected to the hot neutral link bar, could I wire them to the the second DB board (with the ATS) in a neutral link bar that goes directly to the ATS instead of placing a breaker on the neutrals (which is how it was wired in the main DB board)?
Most of the documentation for the ATS devices seem to include breakers for both the phase and neutral. Just thought this might be an instance where that is not necessary however I wouldn't mind doing it either.
