Auction car has issues
ghostbuster
Forests of JHB
I just bought a car on Auction, newish model KIA, It has some eyelashes glued onto it which looks ridiculous.
They are glued on with some ultra sticky glue. how can i remove it without damaging the lights/paint work.
It also has a very dirty and scummy interior, smells almost fishy. How can i remove the stains and odour?
you brought it, your problem,
take it to a valet to get the interior cleaned up,
fake eyelashes maybe try your best with some solvent, although not sure what to use on painted metal.
Are the lashes stuck to the plastic of the headlight or to the body paint?
I think some detailed pics would definitely help. Help us to help you.
