Come on dude you just bought the car less than a week, it's already making funny nose. Take back to the garage demand your money back and get Honda Jazz.
It's also quite ironic that the Honda Jazz is notorious for getting a whine on the CVT gearboxes.What's up with you these days? A new personality to go with the username? You know very well that OP bought a used car, it is expected that a few issues here and there should be expected on a used car, who says a Jazz would not have issues?
Bought from private seller so no recourse... Wish I could find a jazz in my budgetCome on dude you just bought the car less than a week, it's already making funny noise. Take back to the garage demand your money back and get Honda Jazz.
I have googled and see many options but looking for a reference from someone who has used one of them and can recommend them to meA colleague was stressing about a whining noise which he thought was coming from his auto box on a Corolla, turns out it was a belt tensioner bearing that was gone, Toyota did not let him off lightly, he was also told about the belt that has apparently been stretched due to the faulty tensioner. More than R4000 in total he had to part with to fix the issue.
Maybe just check if the noise is really coming from the gearbox. You can also Google any gearbox place in Randburg, there must be a couple in Strydompark alone.
Bump
How bad is the noise, why didn't you pick it up when you test drive it?
It may also be those good ol new car nerves, every little whine or clatter sounds like the engine is about to explode or the suspension about to drop onto the floor..
I'd first Google the hell out of the issue, find other Nissan models that also use the same gearbox, could easily just be that it needs a gearbox fluid change and/or gearbox filter.
Also how sure are you that it's the gearbox and not something else making the noise, does the gearbox have any other signs of not being so hawt?
I did reply see below
That's exactly why I need an honest gearbox specialist who will tell me if the issue is not so serious
I've got 3 opinions now that the noise is gearbox related including Nissan themselves
Then read again because you skipped a few things.
I hate trying to help morons, my gearbox whines boohoohoo, ok what else is the gearbox doing that would make you think it's faulty? Radio silence.
You are being that guy who wants to save money without actually doing any legwork, read my reply again and follow it. Or alternatively stop whining like your gearbox and take the car to Nissan/whoever and just cough up the money, like a lamb to the slaughter :crylaugh:
Glad you agree champ.... No need to be so immature
Anyways, do you have any advice for me champ?
Any places you can recommend or steps i can take?
