Code:
' * Initialize some variables. * '
Dim strDUN
strDUN="Your dial up name" 'Eg iBurst connection 1
username="yourusername"
password="yourpassword"
arrayBadip=Array("64","65")
msgbox "Connecting to the internet."
incorrectIP=true
while incorrectIp
InternetConnect
ip=GetIp
incorrectIp=false
thirdOct=ip
thirdOct=right(thirdOct,len(thirdOct)-instr(thirdOct,"."))
thirdOct=left(thirdOct,instr(thirdOct,".")-1)
for i=0 to ubound(arrayBadip)
if thirdOct=arrayBadip(i) then
'uncomment the line below for debug
'msgbox "wrong ip:"&ip&" third octet:"&thirdOct
incorrectIp=true
InternetDisconnect
end if
Next
if incorrectIp=false then
msgbox "You are now online."
end if
wend
' * Subroutine to connect to the internet. * '
Sub InternetConnect()
commandLine = "rasdial "&strDUN&" "&userName&" "&password
Set WshShell = CreateObject("WScript.Shell")
call WshShell.Run (commandLine,8,true)
set WshShell=nothing
End Sub
' * Subroutine to disconnect from the internet. * '
Sub InternetDisconnect()
commandLine = "rasdial "&strDUN&" /Disconnect"
End Sub
' * Subroutine to get ip address. * '
Function GetIP()
Dim ws : Set ws = CreateObject("WScript.Shell")
Dim fso : Set fso = CreateObject("Scripting.FileSystemObject")
Dim TmpFile : TmpFile = fso.GetSpecialFolder(2) & "/ip.txt"
Dim ThisLine, IP
If ws.Environment("SYSTEM")("OS") = "" Then
ws.run "winipcfg /batch " & TmpFile, 0, True
Else
ws.run "%comspec% /c ipconfig > " & TmpFile, 0, True
End If
With fso.GetFile(TmpFile).OpenAsTextStream
Do While NOT .AtEndOfStream
ThisLine = .ReadLine
If InStr(ThisLine, "Address") <> 0 Then IP = Mid(ThisLine, InStr(ThisLine, ":") + 2)
Loop
.Close
End With
'WinXP (NT? 2K?) leaves a carriage return at the end of line
If IP <> "" Then
If Asc(Right(IP, 1)) = 13 Then IP = Left(IP, Len(IP) - 1)
End If
GetIP = IP
fso.GetFile(TmpFile).Delete
Set fso = Nothing
Set ws = Nothing
End Function
Fill in your details connection name username password and viola.
Run the app ... If you have trouble and need to stop the loop you will have to hit ctrl alt del and click processes and kill wscript process.
This will not work AFAIK if you have not dialed in using this method already
