AV Wireless sender/receivers Wifi Interferance
Aharon
Hi
I have bought an Ellies AV Wireless TV Signal sender receiver. Is there any way to block the terrible wifi interference that it picks up (besides switching of the model or getting a non-wifi edition).
Thx
Cant you change channels on it. It does use wifi spectrum. Also change your router to another channel.
I had the same problem .the AV is analogue so the wifi will interfere with it ,i eventually wired the TV.
The microwave also used to interfere with the AV sender.
I always asked my clients to wire. AV senders are extremely problematic. We do not even sell them anymore, because of the amount of returns we had...
If one could buy one of those HDMI connectors that handles the "handshake" part (iirc), could one not route it through an HD video capture card and stream it via the WiFi network? My media box streams perfectly over my wireless router...
Also eventually got rid of ours. Having to try jiggle the cables or move the device was annoying
Hi
Thx
You can buy a 5.8Ghz or 1.2Ghz receiver.Check on bidorbuy for sellers
Thanks everyone. JustAsk - why are those better?
