Do any of you ever get any issues with port forwarding and axxess uncapped? I'm having trouble getting torrent ports unblocked on my axxess account, while on my Afrihost account it seems to work fine.
I am having issues trying to view my Camera's externally, I am with Axxess and my Fibre Line with Vumatel.
The Wifi router has port forwarding feature however with my previous service provider i had Wireless Microwave Link i was given access to the Mikrotik router and i opened whichever ports i needed, not sure if with the Fibre it works the same way ?? Any suggestions ??
Hi Thanks for your reply, i called Axxess asked them for the user name and password for the back end, they said "they do not manage port forwarding i must go to portforwarding.com" 2nd response is i had to get hold of Vumatel, i then called Vumatel they referred me back to my "Upstream Provider" QUOTE : " When enabling, it is not on the CPE devices. That is configured specifically by the upstream provider to allow authentication on 1 port for DHCP. "Yes it should be exactly the same. You would need to login to the router and then you would be able to forward the ports from there or use a DMZ function if you wanted too.
Hi there @Gino21665, Please drop me a mail at [email protected] and I'll have a look for you.I have a Tenda Router coupled with CPE device
