mkmanyowa
I have a Samsung Galaxy J5
When i use my ordinary MTN pre-paid sim, i do not struggle to use my cellphone's tethering and hotspot feature.
But when i put my axxess data sim, my tethering refuses to connect, and when it does, it gives a limited connection.
On the phone the data works fine, but once tethered it will not. I have tried to connect to 7 other devices with no luck.
Also, when i remove the axxess sim, and put the MTN prepaid, then put the axxess sim back in the phone, i struggle to even get internet connection.
First the APN keeps reverting back to the MTN Data APN on restart. After maybe 5 or 7 restarts, it does not revert, but will not pick a default APN. Even if i choose, it does not do anything, and i have to restart several times, and eventually i leave it for maybe 15mins then it connects.
I use the following APN settintgs
APN: yourmobile
Data bearer: unspecified
(Note: the line is LTE enabled, but if pick LTE as a data bearer, i don't get internet at all.
Any help?
I have tested the sim with 7 other devices, different one's. Same issues.
UPDATE
SOLVED
Solution is to go on APN Type
Add the following line *add text inside the brackets only* = (default, dun)
No response from axxess lady, or anyone, had to figure this out on the own!
APN: yourmobile
Any help?
UPDATE
SOLVED
