Axxess line speed upgrade
bear786
Hi
I recently migrated from Afrihost to Axxess.
I was on a 2mb package with Afrihost.
The package I selected on Axxess is a 4mb package.
The migration was successful. However, after speaking to someone at Telkom, I was told that my line is still at 2mb. I was also told that because my line was being managed by Axxess, they would need to process the upgrade to 4mb.
(I only found this out after creating a bunch of tickets...)
I have done so but it's been days and I am no closer to getting my desired speed.
After asking a few times, I was eventually given an order number for the upgrade.
Using the telkom website I checked the status of it but it makes no sense to me.
The status is "Checking stock in our warehouse☺" and the description is "Main Component - Wholesale ECDSL".
What does this mean and how long does it take to upgrade line speeds?
Been struggling with this since last week...
Thanks Scary_Turtle. I'll give it a shot (fingers crossed...).
You can upgrade your line to 4Mb through the Axxess portal with a few clicks if your line is with them. Takes a day or two to take effect. No need to log into the Telkom portal at all..
On the portal, it says "Service: ADSL Line up to 4Mbps - 02......."
I've been specifically told it's still a 2mb line by Telkom.
Just got a call from an Axxess consultant. He said that there is a problem with my attenuation and sync speed.
He says it's probably the reason for the delay.
Guess I'll just have to wait and see...
EDIT:
My Downloading Status:
Download Speed - 1416 kbps
Noise Level - 28 dB
Signal To Noise - 11.7 dB
My Uploading Status:
Upload Speed - 512 kbps
Noise Level - 49 dB
Signal To Noise - 15 dB
