PaulNOTsaul
- Aug 4, 2018
I have noticed that over the past month Axxess has being experiencing technical, support issues. If its not problems with their LTE, hosting etc, they is over 123 notifications about faults they having, I mean one was issued 20min ago.
The clientcare department is gotten from bad to worse, it takes about a week to get feedback, and when you do they will ask you:
" Hi,
Are you still having the same problem?
Kind Regards"
Sometimes whe you do call their 0861 number you actually get " Sorry, this number no longer exists"... If you luckly to go through you hold 20minutes...
I can go on and on..... Is anyone still having the same problems? Axxess was never this bad...
" Hi,
Kind Regards"
