Backup power <3KVA
Gitesh
Hi,
I am looking to get an Inverter and lithium batteries. There seems to be a lot of good 3KVA and larger units on the market. I am living in an apartment and just need the to have the lights, TV and internet on as well as charge my phone. I will get an installer to connect it into the DB board. The one options is to go with a 3KVA system but I would appreciate advice and recommendations on smaller Inverters. I found these two online.
1. Deltec 1600 Watt 24 Volt Bt-Sm1624
2. Fivestar 1.2KVA 1000w PWM 12V Solar Hybrid Inverter
Thanks in advance for any assistance.
If going 24v i would want 3000w min ie to be able to use micro in a pinch
If going 1600w and know you will never want to do that iw ould go 12v and one battery if wanting to expand capacity you can ad the second battery later
ie like this one
But like i said if laying out the cash for 2 batteries or 24v 3000w minimum imo
