Greetings Fellow Beings,
My local LAN setup consists of 4 workgrouped pc's in an ethernet network. I have a Netgear DG834V5 router attached to an 8 port switch. All pc's are running XP.
My pc's are setup with static ip's in the 10.10.10.x range on the ethernet adaptor for specific reasons required by a retail application,
The netgear router resides on the default 10.0.0.x range. I have setup each of the pc's with ip aliases so that they can connect to the 10.10.10.x (local LAN) as well as the 10.0.0.x range (WAN) for internet connectivity.
I am now required to measure the WAN bandwidth being used by each of the 4 workstations.
I have tried ShaPlus Bandwidth meter only to find that it measures "all" traffic coming in and out of the single ethernet adaptor. The only other solution would be to install a 2nd NIC, but I only have 1 wall mounted data point per workstation. Would one be able to source a "splitter" for this ?
Also, would windows SNMP also yield the same results as it would not know the difference between the LAN and WAN traffic on the NIC?
Last question is, would the Netgear have something available in the router firmware to accomplish this?
Much appreciated.
Japman.
Much appreciated.
Japman.
