Banks scoring method for bond approval
calgal90
Hi Everyone,
My understanding is that the banks use a specific method of scoring an individual when applying for a bond. Does anyone know how the scoring model works? I remember someone explained in a post, but I cannot seem to find the post :(
You can buy a R1mil house and the whole process takes up to a month, and your whole pedigree is scutinized, or you can buy a R1mil car and drive it away the next day.
Hi Everyone,
Each bank has their own scoring model that looks at factors that they have found, in their experience, to be predictive of non-payment. Exactly what the factors (and how much they each count) are will depend on the bank and possibly even on the type of product that you are applying for. None of the banks publish what their models are so you're not going to have too much luck with getting the details.
If you want a more theoretical discussion on how these models are built and how they work, let me know and I can help you out.
Thanks, I would like to know more about how they work.
Here we go:
The industry standard for retail credit models is a scorecard approach. For a very detailed book on how these models are built see "Credit Risk Scorecards" by Naeem Siddiqi (This is 200 or so pages so I'll try to give a summary here).
Simplistically, the way these models work is by having a set of factors (e.g. age, qualification, income, loan to value etc.). Each of these factors is divided into groups called buckets (e.g for age the buckets might be 18-25, 25-35 etc). Then each of these buckets is assigned a score, usually with higher scores indicating lower risk. To get a person's final score, their score for each factor in the model is added together. There is no standard range for these scores but bank's will usually have a cut of below which they will not lend money.
As you can see, using a scorecard model is very easy, hence their popularity for retail credit risk modelling.
Building the scorecard is quite a lot more complicated though. And will follow the process below (more or less):
  1. Start with a long list of potential factors
  2. Bucket the factors
  3. Discard factors that are not appropriate
  4. Pick the combination of factors that gives the "best" model
  5. Decide on the location and scale of the scores
  6. Create the scorecard
  7. (Optional) Map the scores to a Probability of Default
The long list of factors will generally be either all of the data that is available or it will be a subset of that that is decided on by the modeller and credit risk experts.
Some factors are handily pre-bucketed e.g. qualification. Others are not. The ones that are not are bucketed by maximising a measure called the Information Value. This measures how much information the factor give about payment versus non-payment. This is usually done iteratively but there isn't really a simple way to do it so it often comes down to gut feel and "good enough".
Once all the factors are bucketed, each factor will be examined for a few things:
  • Does it have a sufficient Information Value and/or Gini Coefficient?
  • Is the Weight of Evidence monotonic? (Weight of evidence measures how "good" people in this bucket are relative to people in the other buckets)
  • Does the factor logically and intuitively rank risk?
The first point talks to whether the factor can distinguish between high and low risk people. The second talks to whether the factor ranks risk in a particular direction. The final point talks to whether the factors are reasonable (e.g. statistically what a person's favourite colour is might be very predictive but there is no logical reason for it. Also there is no reason why people who like red should be better than people who like blue or vice versa)
Now the list of factors have been narrowed down to a much shorter list but a list of factors is still not a model. At this point it is time to build the actual statistical model. There are many techniques to do this but the most common is a stepwise regression (this basically starts with no factors and adds the most predictive excluded factor at each step until a certain accuracy is reached or the additional factors do not add sufficient accuracy to the model as a whole). At this point a lot of analysis is done on the factor selection to make sure that the factors are not too related to each other and that the model is adequately predictive and that the factors included consider every relevant aspect. This is more art than science.
The next step is to decide on the scores. For these models, it is usually specified by 2 parameters: a score for a certain odds of non-payment and a number of point to double (or halve) these odds. There isn't really an industry standard for this so there can be vastly different choices across different institutions but it doesn't actually make a difference to how the model works.
Last step is to assign scores to the individual buckets for the chosen factors. This is pretty simple once all the above steps have been done because it is basically a combination of that bucket's Weight of Evidence and the factor's weighting in the model.
Voila, you now have a scorecard.
The final optional step is using historical data to map the score to a probability that describes the chance of a person with a certain score defaulting on his/her loan over the next 12 months.
And here I thought they just shook a magic 8 ball..
That's the only explanation I could come up with for the bizarre spread of responses we got.
I have never had a credit card or a loan and I got my bond just fine. Perhaps my cell contract counted for something but at the end of the day I think they mostly looked at my bank statements, salary slip, and the fact that I had saved up a 20% deposit.
Except the person buying a R1m house can't afford a R1m car. :)
As long as your affordability makes sense then you shouldn't need any of those.
It's when you are toeing the line that your credit record comes into question.
Also sitting in the same boat. Only ever had a cellphone contract. No other forms of credit. Will be applying today so fingers crossed
You would think this is how it works but its not. Ask a business owner that could easily afford to purchase a vehicle cash how hard it is to get vehicle finance.
While I don't have direct experience of working in the loans department, from everything I've heard, the primary factor in determining your interest rate is your credit history. I'm sure your bank statement (affordability) is factored in but to a lesser degree.
The question wasn’t about interest rates, it was about getting the loan in the first place and there they really only care about month to month affordability.
Same applies to the business. Even if you sit on a million rand in a savings account if you apply for a loan the month to month is all that really matters because that million rand isn’t secured in any way it’s just an offset.
