BASH Script Help
Silver-0-surfer
CPT
Hi Guys. I really need some help with a script Im trying to write.
I have a GNS3 server and just for grins I wanted to make a script that would open a new gnome-terminal, telnet to the console port and set the title of the shell. So I googled and found this should work
gnome-terminal --tab -e 'telnet 1.1.1.1 2000 ' --title=R0 --tab -e 'telnet 1.1.1.1 2001 ' --title=R1
this works fine, but as the labs differentiate I wanted it to be dynamic so i made(making) a small script, this is what I have
Code:
#!/bin/bash
#Define some variables
counter=0;
command="gnome-terminal "
#Get info from user
echo "Enter the amount of routers to connect to";
read amount;
echo "Enter the IP Address of Dynagen/Dynamips Server";
read ip;
#Build command
while [ "$counter" \< "$amount" ]; do
newcommand=" --tab -e  'telnet $ip 200$counter ' --title=R$counter ";
command="$command$newcommand";
counter=$[counter+1];
done
#Run command
echo $command;
$command;
(the echo $command is just used for trouble shooting)
the result is this
[admin@user Scripts]$ bash gns3.sh
3
1.1.1.1
gnome-terminal --tab -e 'telnet 1.1.1.1 2000 ' --title=R0 --tab -e 'telnet 1.1.1.1 2001 ' --title=R1 --tab -e 'telnet 1.1.1.1 2002 ' --title=R2
Failed to parse arguments: Argument to "--command/-e" is not a valid command: Text ended before matching quote was found for '. (The text was ''telnet')
if i run the output manually (gnome-terminal --tab -e 'telnet 1.1.1.1 2000 ' --title=R0 --tab -e 'telnet 1.1.1.1 2001 ' --title=R1 --tab -e 'telnet 1.1.1.1 2002 ' --title=R2) it works but the script ALWAYS fails with
any ideas?
your ' is getting eaten by the bash shell when try to execute the gnome-terminal from within the bash shell
escape where you build up the command (added \ in front of the ')
newcommand=" --tab -e \'telnet $ip 200$counter \' --title=R$counter ";
