Basic routing issue - help needed
[OUPA]MrNutz
Vereeniging
Hi MyBB people.
I need to ask for constructive views/guidance:
Smallish network.
*Router (A) -IP 172.16.1.254 <- This shall provide internet feed to 5 other smaller wifi routers , as static inputIPs. (all good)
-please note that DHCP is off (A) as there is another DHCP server running on the network for a legacy IP phone system. (no VLANS available)
*Internet is inbound received via a Telkom Metro fibre (cisco router) 196.43.x.y (B)
*Setting the static ip on the 172.16.1.254 , i receive IP flow from (B) but no DNS. (can ping internet traffic)
*i have tried the cisco router's (B) DNS , Telkom's DNS & Google DNS on the router 172.16.1.254. (A)
*Wifi client routers have DHCP going , all shall be ok once i figure out how to "forward" dns from (B) to (A)
*(B) plugs into (A) as wan port
*(A) plugs into normal switch
What am i missing? - forwarding of some sort ? Seems that router needs to forward WAN side DNS but it doesn't. Shortfall of no dhcp? Surely manually must be possible.
Yip - noob101 , alas my humble plea for assistance :)
Try and draw a diagram. It might help you figure this out. And us figure out what you are talking about.
It must be late, Im not really understanding this.
But some questions anyways
1. What is the network between router A and B, since you need to default route from A to B, is that setup?
2. Where are you testing ping from? There shouldnt be anything special about DNS traffic over normal ping with regards to routing, I doubt there are any access lists, so if you can ping the DNS server, you should be able to access the DNS server
Could be the metro fibre not allowing passthrough DNS? Set DNS Upstreams for each router to the one above it in the "waterfall"
Thanks guys - i'll try the same dns as test -
Requirement:
wifi router (with dhcp) (C) , has relayed internet flow from, WAN port , from
router (B) (fixed ip with no DHCP) , receiving from , WAN port , from
cisco metro fibre router (A) (no DHCP , saix IP block) .
I am going to check a manual add of dns on C and B to see if it might help and test with laptop also for manual DNS...
I've had similar with Neotel where you had to use the provided router as the upstream DNS
bouncing dns lookups should not really be needed.
I would just put the DNS on the laptop, and test.
Use google DNS, then use the metro router IP as DNS.
