How old are the Pylons? Cheapest will obviously be adding just the one more.Hi,
I have 3 pylontech us3000 batteries in my system, do I add one more or replace them with a Dyness 14,3 kw battery
Have 2 us3000 and 1 us3000c
Does it matter?How old are the Pylons? Cheapest will obviously be adding just the one more.
Well, kind of. If the SoH of the older batteries is say 80%, I'd strongly consider replacing them.Does it matter?
Then I'd definitely just add another one.Soh is 99% less than 400 cycles, us 300 around 4 yrs old, us3000c about 2 years old
Why?Well, kind of. If the SoH of the older batteries is say 80%, I'd strongly consider replacing them.
Internal resistance issuesWhy?
Why is that an issue? The new battery will have the lower resistance so will take load away from old batteries. One of the reasons why you rotate the new battery in as the master.Internal resistance issues
