Other Pineapple Smurf
Time to put my striker lock and access control onto a battery thanks to load shedding.
Requirement: Gate gets used up to a dozen times an hour. The goal is to open around 20 times on a charge but an MVP of 10 times will be perfect as load shedding hit's just as we have clients arriving or if load shedding is at night and we don't use the genie / alarm company needs access to the property.
Current setup: No backup, needs to be plugged into the generator which I don't always switch on if I / my wife is not working.
Spec:
1 - CISA RIM LOCK (Don't laugh you smutty Pineapple Smurf) : 11630-60-2 – LH
* Steel case and striker, painted aluminium grey
* Dead-locking latch
* 12 V ac CE
* Rated current 2,5A
2 - Have two remote receivers - since nobody has a standard my keypad and remotes are different brands
Question: Would an alarm battery 12V 7Ah be strong enough, or do I need something stronger ? I like the idea of using shared battery size as that is what my alarm uses.
If the above battery will work, to charge, would I just use a common 3.2amp charger: https://www.takealot.com/sherlo-tronics-battery-backup-power-supply-3-2-amp/PLID47439684
I'm comfortable building my own using my existing components and buying anything needed from https://www.robotics.org.za/ etc but I'm still new to electronics. Only just getting into IOT / Arduino this month. (Want to add a ESP32 module still to the gate for open/close status and remote control).
What I currently have, a 12V 3amp power supply and two recievers (flame me with my prototyping). This of course is all going to be installed in a proper housing.
Spec:
* 12 V ac CE
