Hi!
I'm starting on my journey to convert some of my load to solar. My first step is to have a battery backup. I'm considering buying a goodwe GW5048D-ES 4.6kw inverter and 2 pylontech 3.5 kwh batteries.
Shopping for the equipment is easy, there are many shops to compare. I'm trying not to be fleeced on the installation costs.
The quote I got from an installer recommended by the online store is as follows:
The "Installation and commissioning of the inverter" sounds like hanging it on the wall and going through a couple of steps to set it up...
Can anyone recommend someone in the centurion/midrand area ?
Thanks!
- R5600 - Installation and commissioning Of 5Kva inveter and two Pylontech storages Units
- R1750 - Equipment
4 way surface DB
20m 4mm x 2 Core and earth
40A change over switch
Surge protection Arrestor
Consumables ( trucking, lugs, cable ties, ) - R1750 - DB Connection and rewiring for Solar connections
Thanks!
