TheMacintosh
- Sep 4, 2012
Hi!
A quesiton for the power experts.
I have a 600w SPS600 inverter trolley which have been my life saver. It runs a few lights, internet, alarm, work station and TV. My deep cycle GEL battery is coming to an end after quite a few years of service.
With the pending worsening of load shedding I'm looking to double my standby time for longer power cuts. I also ordered 400w worth of 12V solar panels that will charge the batteries during the day (inverter has built in 12V solar charger)
So my thinking was to order 2 x deep cycle GEL batteries and connect them in parallel, which should give me almost double the standby time. This would cost me R6500 for the two GEL batteries (12V 100Ah).
The other option is to go with a drop-in Lithium (LiFePo4 12V 100Ah) , but I would only be able to afford 1 @ R8000.
I do understand that the GEL batteries have a shorter time span, and less cycles. But looking at how my previous battery lasted since 2019, the GEL batteries does not seem to be that bad. Especially looking at the cost.
So giving my need for longer standby time, does it make more sense to go with the 2 x GELs? Any thoughts on this?
Thanks in advance
Thanks in advance
