battery monitors
genicide
I want to monitor my 16 x 12v 180ah batteries, what is the best monitors and price please
Sounds like you have a large setup so surely the gear you use have monitoring functions?
What are you trying to do?
Which inverter are you using.
As previous poster said that should all be included and programmable.
Victron is probably the best.
My inverter is a devel lpt 6kw I have 18 x 300w 48v solar panels 2 x 60A mppt and all 4 battery strings are on a bussbar so I am thinking of getting a victron bmv 700, I don't need the 702 because the midpoint is not going to be used because of the common buss, what do you guys think
