battery qarantee?
upup
currently offline
how long does the qarantee last on a new curve battery. ?
It made a buble and last 1 hour.
I assume you mean warranty, how did your spell check not pick that up?
Anyway, you should enquire from the vendor of the battery - the warranties will differ from brand to brand.
The warranty on a cell battery is 6 months. You mentioned new, if it's still under 7 days that would probably qualify as a OBF. Take it back to where you purchased the phone.
