I made a battery runtime calculator from a formula I found here on MYBB, I'll fetch the thread now now ( on my phone so search is iffy )
Let me know what you think and what other options I can add, battery types and inverter types, if needed.
erikthiart.com
Battery Run Time Calculator Using Watts
Use this battery run time calculator to determine your run time or the battery size that you need for your use case.
