Belkin N1 Wireless Modem Router help...
myles
Im new to routers etc...
This is the setup...iBurst UTD (old model) via lan connected to Belkin N1 and then Belkin connected to PC via lan. The PC is running Vista Ultimate.
Id like to connect PSP and Nokia N95 (and future XBox 360) to the "wireless internet" but im having problems setting it up.
Do i need to set the router as an access point? How do i get the router to make the connection to iburst? Does the pc need to be on cos i thought the router would make the connection so long as there was power and iburst was connected to the router via lan cable.
you need to enable your wireless on the router... then specify encryption type for your wireless (to avoid people from stealing your internet... then you just join the wireless network with that phrasekey
